- Dec 10, 2004
- 67
- 0
- 0
Hi,
It appears that the EZ Selector card is marked backwards or something. I can't get the system to boot with one VGA card in the PCI_1 slot and the selector card with the single video card mode selected. (Single Video Mode connector connected to slot) If I switch the selector to dual video mode then it single card mode will work. This is opposite to what is said in the manual. The opposite happens for SLI mode. Can anyone confirm this? I am also pissed that I can't get SLI to work with the selector set to dual mode as this should enable 8x + 8x. In SLI mode with the selector card on "single" the system shows the 6800 ultra as 16x in the nview properties and SLI is detected. If I switch the connector to "dual mode" SLI will not detect but in nview properties the system now shows the 6800 ultra is running in 8X which appears to be correct as SLI needs to be 8X + 8X. The only way I can get nvidia to detect an SLI setup is to have the connector set to single card mode but that sets the slots to 16x + 1x which is incorrect.
Any help please?
Can someone confirm this same problem?
Is the EZ Selector Card marked backwards?
Can someone please help me get SLI working with dual mode selected?
Thank You.
Asus A8N-SLI
2x EVGA 6800 Ultra PCI-E
Cosair 3200XLPro
Any help please?
Thank You.
Asus A8N-SLI
Cosair 3200XLPro
