Asus A8n Premium max?
yomafire
Hyper Transport Frequency is 2000?
So would that mean I can try 260 FSB and set my HTF to 5x?
Also, I think I should be getting better overclocl on my 3200 E3 setpping. I can easily boot to windows at 2.7 but it doesnt pass prime95. At 2.6 it doesnt either but I can usualy play games (COD2) for a while before it freezes.
My current setting are : -250 FSB
-10x mulitplier,
-running 1:1 ram (ive seen this ram go 300 easily with loose timing and 2.95 volts
-and I set my max vcore to 1.55V (would a bios update give me more volts? Currently I running 1005 bios)
-And my pci is locked to 33.3 and my pci-e is at 100.
Any ideas?
A better overclock? Maybe not, but it may get you better performance.
*waits for someone who knows what they are on about to arrive*
-10x mulitplier,
Any ideas?
No, HTT is 1000 doble pumped...so...u shouldnt go beyond 200 @ 5X or 250 @ 4X or 333 @ 3X ... etc if you are running more than 200 with 5X your are risking data corruption and some other problems...if that just have not happened to you...you are just a lucky guy 😀
