Asus A8N Premium Bootable RAID SATA Help
LexF15
Trying to set up 64bit WinXP on a Striped array - fresh install on this new machine (in sig).
Bios is 1005 and all 4 Gig ram is recognized fine. Using the manual (novel eh?)....
Hooked up both drives to the Nvidia Raid ports - not the silicon graphics (want native spt)
I've tried power using the SATA cables, the old 4 pin molex cables, and never both at once.
I set up the BIOS to Enable NvidiaRaid and the drives I plan to use (1 & 2).
Boots fine, posts fine, can do F8 and F4 to enter silicon graphics raid utility but....
No matter when or where I spam F10 I cant get into the Nvidia Raid utility.
After WinXP CD loads and the F6 option comes up i hit that too, but won't enter there either.
Thinking a couple things.
Power on the drives? Kinda hard to tell since they dont show in POST.
Is the keyboard broke - heck it's new - but F8 and F2 and F4 all work so.....
Power again? I've tried using both power supplies in the case - both come on at once.
I've tried enabling all 4 Nvidia SATA drives as well as just the two I want.
Any ideas? All hardware in sig - I have not upgraded the BIOS
Experienced builder - new to SATA Raid bootable.
ElTorrente
Banned
Aug 16, 2005
483
I've found that the easiest, and most problem-free way to get raid arrays working is to unplug every single drive and harddrive that isn't totally necessary before I try making it work.
Disable everything in BIOS that isn't totally necessary - and of course, make sure you disable the silicon image RAID (which I'm sure you probably did).
The first RAID I setup had the same issue. I couldn't get the computer to recognize that I had disks hooked up and ready to stripe. In fact, I think that not only did I unhook my other drives, but I had to run FDISK before it finally recognized.
LexF15
Hmmm not sure they are even getting power. Not even seen as regular drives (not RAID) when connected to Nvidia SATA ports.
