Spec: -
XP 2200+
512MB Mushkin PC2700
GF4 TI 4600
TBSC soundcard
Maxtor 40GB HDD
Enlight 400W PSU
Chieftec Dragon casing
The problem : - The system will reset the bios everytime I turned the system off...off the power from the wall socket. But if I just turned off...leaving the wall socket switch "on"....then the bios settings will remain.
Done the following: -
1. Nope...not batt problem...coz changed a good working batt & still the same problem.
2. Swap a working Athlon 1GHz & put it in this mobo...same problem.
3. Try removing the raid card & connect IDE devices directly into the mobo...same problem.
4. Try running w/ only cpu,mobo,RAM & VGA card...same problem.
Hope u guys can help.
XP 2200+
GF4 TI 4600
TBSC soundcard
Maxtor 40GB HDD
Enlight 400W PSU
