- Jan 18, 2001
- 388
- 0
- 71
hey all,
Hmm..seems the cause my be my memory, motherboard or Bios settings(see below). since i am able to install winme with np in a non RAID setup, i dont think it would be the memory. so maybe a bios setting or maybe i need to upgrade the promise bios? So all you A7V266e users that have a RAID array..could you tell me if you changed any settingsd in your bios when installing win. Does anyone know if there is a updated bios for the onboard promise card?
Edit: I have been having a hard time installing Win ME on a RAID Array with the ASUS A7V266E. im using Win ME cuz i dont got WIN98SE. its not the HD as i first suspected. I fixed the drive using the IBM utility. resetup the raid array and got the same error when installing winme "suwin.exe at 000C:195A" so i set it up non-raid and installed win with np..so its not the drive or the win disk so maybe the mobo?
End Edit
what a frigin pain in the booty! ok, so i got my new stuff (a7v266e, amd xp1600, ibm 60gxp 20gig) and i wanted to set it up in a raid array using my new 20gig gxp and my old 20gig gxp. i read the instructions and didnt see anything about having to format or fdisk my old hd..so i didnt. was that my 1st mistake? setup the raid array, np. booted up, fdisk'd the array 1 10gig 2 15gig partitions,np. formated the 10gig partition and went to load winme. scan disk was fine started to load windows and got a error "suwin.exe" i think it was. so not knowing what the problem was, i spent several hours trouble shooting..finaly found out the old hd wasnt working. if it was hooked up i couldnt even bootup with a boot didk to try to fdisk it. i finaly managed to bootup puting the old drive as a slave and the new one master. when i try to fdisk it..it says drive not accessable (old drive..new drive np)..it shows as a 20 gig drive with 1 10 gig partition. i was able to formate the 10gig partition..didnt help any.
is there anyway to fix my HD?
thanx for help
End Edit
thanx for help
