I built a computer consisting of:
Asus A7V133
AMD T-Bird 1.2GHz (200MHz FSB)
Crucial 256MB CAS2 PC133 DIMM
ATi Radeon 64MB (Retail)
And other various parts, but these are what could possible be related to the problem.
Last night, I set up the machine.
The jumpers are all default (JumperFree mode)
In the BIOS, the only thing I adjusted was drives and setting the DIMM speed to 133. The CPU is at 100x12.
It worked perfectly fine for the evening, no problems. I even put the case back together. The highest temp I saw with the AsusProbe was 53C. That was with the box all closed up and it still ran perfect.
I shut it down for the night...
This morning, all I did was unplug the drive cables and make them nicer for airflow from the lower case fan I put on.
Booted up fine, played a little Blade of Darkness, Quake3, ran like a dream.
After that, I thought about flashing the BIOS to the newest version. Downloaded the AWD file and flash.exe. The executable downloaded a little sketchy (bad isp) so I checked it by executing it, prompted to hit ESC to exit, I did... It worked fine... But I did NOT run the program in any way beyond that.
After that, I surfed a little and then let the computer alone to get ready for work.
That's when I heard the monitor re-sync. Thought it a little strange I sat back down and it did it a couple more times. Figured it best to power down and boot again.
After reboot it didn't take it very long to flicker again, this time locking up the machine. Rebooting provided the same results.
Rebooting again however got me nowhere.
I do not get a video signal, I cannot access the BIOS, all it does is sit there and beep.
The beep starts low for about .5 second then high for the same and loops. Kind of like a crappy digitized foghorn looping over and over.
What I've done:
Checked the CPU. The shim is still very well in place, the Arctic Silver II is making good contact with the HS, but not too much. Can see through the layer after removing HS.
Put two different AGP video cards in.
Put a different DIMM in.
None of this fixed the problem.
And from what I can tell, this particular beep code is not described in the manual.
Why don't I think it's temp?
Well, the computer ran fine, at higher temps and was perfectly stable. And the ambient temp this morning was much lower as well.
Well, I'm pretty lost as to what it is, hope this is enough info and that someone can help... As of now, I'm losing faith and I think I'm about to have a very expensive paper weight...
- Mike
Asus A7V133
What I've done:
- Mike
