Yesterday I got my new powerunit, processor, motherboard, RAM and cooling fan. I put everything together, and started up my machine. Now there are some points I know very little about. They are clock frequencys on RAM and CPU, and hard-drive connecting to Ultra-ATA-100 or what it's called. What I need help with is this :
My cpu is now running at 900MHz. That is 100MHz cpu frequency clocked by 9.0 multiplier ratio. The RAM is running at 100MHz too, though it's 133MHz RAM. How do I get it up to 1,2GHz and get most out of the RAM ? I had some Windows problems yesterday, so I had to reinstall it, now I really don't know wether the processor or Windows was the trouble, but some setup instructions would sure do good.
My hard-disk is now plugged into the Primary IDE Connector as MASTER. Can I simply put the motherboard connector over to ATA-100 connector, and it will work as ULTRA-ATA-100 ? My HD is made for ULTRA-ATA-100 before you ask So can I just put it over there, or do I have to format or run anything ? I'm not going to use RAID.
Will be VERY happy for some help, and please, don't be too brief
