I just upgraded to a 1.3ghz Athlon and have a Thermoengine V60-4210 that's rated up to 1.5 ghz. My idle temps are between 55-60 C with up to 65 under load though I've yet to have a lock-up. I am running on an Asus A7v mobo which doesn't officially support this processor speed since the maximum mulitplier setting is 12.5x. The fix for this was offered in bios version 1007 (I think, this is the BIOS I am using though) which automatically overclocks the FSB to 105mhz when you set the multiplier to 12.5x. SO, I'm assuming that the board and processor would be running a little hotter than normal because of the higher FSB speed, but doesn't this still seem a little high? I just installed this processor a few hours ago and have already reinstalling the heatsink/fan to make sure all was well. Case cooling is acceptable right now as I have plenty of fans blowing air through it. I have the CPU voltage set to 1.65 in my BIOS however it is being reported be SiSoft Sandra as being 1.73? Is this odd? Why is this thing so hot!?
EDIT> What exactly is the default voltage setting? If I set it in my BIOS to auto, Sandra reports it as being 1.83!
