Asus A7N266VM IDE LED Troubles
Zedtom
I just put together a system with an Asus A7N266VM. Everything is running smooth, but I can't figure out how to hook up my hard drive LED connector. The twenty pin panel in the manual shows an illustration, but it doesn't show an IDE LED.
Does anybody have this board? This is the first mobo that I've ever assembled that doesn't have one.
I have a few 😀 The IDE connector isn't in the 20-pin set, it sits by itself to the left of it. The pins are one above the other (vertical). Hope that helps you out 😎 If you don't see it, check page 26 of your manual.
Thanks mechBgon. I looked at the board, I looked at the manual, I looked at your post, I looked at myself, I looked like a fool.
