- Jul 18, 2002
- 2,149
- 1
- 76
Ok this is the setup:
From Newegg:
AMD Athlon XP processor
A7N266-VM AA mobo
Kingston PC 2100 RAM
350W Allied power supply
Compgeeks:
WD 80 GB HDD (refurb)
Now this is what happens, whenever I try to install windows 2000, the memory dumps a few times, but in the end the installation is complete. So now I want to use the XP upgrade that I got from school to get XP on this machine.
First:
1. when the XP setup screen comes up in windows 2000, it has lines running through it, kinda looks like how it does on a laptop when the LCD goes bad.
From this I kinda figured, it's either the Motherboard or the RAM. Problem is I dont know which one it is exactly cuz I dont have an extra stick of PC 2100 RAM to use in this PC.
Is there a way for me to tell whether its a problem with the motherboard or the RAM?
Thanks in advance,
Ravana.
*EDIT*
I forgot to add this, I tried installing Red Hat & SuSe to make sure it wasnt stupid windows.
Red Hat 8.0:
Once you get past the test the CDs and its gonna load the anaconda (??) installer, it just hangs there
SuSe LiveEval 7.3:
kinda the same thing with SuSe, it hangs about the same spot.
From Newegg:
A7N266-VM AA mobo
Compgeeks:
First:
Thanks in advance,
Ravana.
*EDIT*
Red Hat 8.0:
SuSe LiveEval 7.3:
