Installation
Aston Shell 1.9.1 (with the crack) should be available on the ftp soon.
The installation is pretty straightfoward
1. Run the setup than
2. If you are running Aston, switch to Explorer.
3. Close Aston Master and Theme Wizard if you have them running.
4. Put the file PatchAston191Eng.exe to Aston directory (maybe "C:\Aston" or
"C:\Program Files\Aston") and run it.
5. Press "Next" for 3 times.
Applying Themes
Themes can be downloaded at h**p://www.astonshell.com
To Install the themes all u need to do is extract the files to your c:\Aston\Themes folder
You need to run the Theme Wizard to apply a new theme.
just choose any one and say ok
Aston Master
Now for the mos interesting part of Aston all the various options.
To get to Aston Master just Right click on the desktop and goto settings
The following images should explain everything
http://dylanf.servegame.com/Aston2.jpg
http://dylanf.servegame.com/Aston3.jpg
http://dylanf.servegame.com/Aston4.jpg
http://dylanf.servegame.com/Aston5.jpg
note Add adds a plugin and delete removes it from the list to keep it on the list but disable it uncheck the check box.
Also note that the vert panel and the panel plugins are setup in the same way as the left and right toolbars
also if u want all your desktop icons back on the desktop (dont know why)
go to aston master->desktop->settings and click get explorer icons
If u have any more questions feel free to ask.
Applying Themes
Aston Master
