Assuming you could travel at the speed of light..
Bumrush99
3,334
194
How could you be sure that the spacecraft wouldn't hit misc space junk like the Asteroid belt between Mars and Jupiter? Also, assume that you can not plot out the entire voyage before leaving. Can you even see what's ahead of you at that speed and have enough time to react to it?
SSSnail
17,458
83
86
Easily, make sure that I leave enough space between myself and the object. Maybe 2 light seconds, it should work the same, no? Count with me, 1001...1002. There.
puffff
2,374
make the spacecraft indestructable so anything you hit would just bounce off.
- or -
mount some sort of super gun at the front of your ship and fire constantly, blasting anything in your way.
bignateyk
11,288
7
- or -
But how could you fire something foward when you are already going at the speed of light? *Head asplodes*
Fritzo
41,920
2,162
- or -
If you were travelling at c, you would be pure energy and no longer matter, so you would not be tangible and objects would not harm you.
Bumrush99
3,334
194
- or -
So technically you could fly through a solid mass object like a planet? So the only thing that could stop the spacecraft would be a black hole?
DaveSimmons
40,730
670
That's what the deflector shields are for.
Forcefields are at least as practical as near-lightspeed travel, let alone FTL.
Ramjet drives even depend on running into matter to use as fuel.
Jeff7
41,596
20
What happens when a beam of light hits a planet?
Splat, now you're heat. Maybe the energy that was your arm will be refleced back into space, giving you the luxury of being able to deliver to the planet a superluminal flip-off.
A deflector would likely be needed to push away interstellar hydrogen, or else the front of the ship might well erode away. It'd have to be damn powerful though.
Concerning ramjets or Bussard collectors, I read that they'd need to have such an incredibly powerful magnetic field in order to channel in hydrogen at high velocity that they'd never stand a chance of yielding a net energy gain.
Fritzo
41,920
2,162
- or -
Well, I supposed that part of you would be absorbed and turned to heat. It would take infinite energy to propel matter at c though, so it ain't gonna happen anyway.
AMCRambler
7,715
31
wouldn't it have to be the speed of light squared in order for you to have turned to energy? Thinking of Einsteins theory of relativity here. E=MC^2
Flyback
1,303
I would highly argue against going at the speed of light if you ever want to see your family again ;) (relativistic change--ain't it a b!tch?)
Kntx
2,270
You cannot see ahead of you. When traveling at the speed of light from your perspective the travel time is 0.
toolboxolio
872
Just send a lot more regular spaceships instead of safe ones.... some will survive the trip. It would be great to have all them make it every time.
VTHodge
1,575
Why assume that? Plotting the exact path to avoid collision seems to be the best solution.
sdifox
101,027
18,144
WARP, people... traveling at light speed doesn't get you anywhere.
Fritzo
41,920
2,162
Not to mention how you slow down. It would take forever to get up to that speed without splattering the pilot into goo. Slowing down would take just as long.
jdini76
2,468
You need to put your coordinates through the nano computer. If you didn't you could bounce off a planet. Traveling through hyperspace isn't like dusting crops boy!
LordMorpheus
6,871
At the speed of light you'd get there instantaneously, as far as you were concerned. You get spatial dialation as you approach c, when you are going at the speed of light the distance between you and the place you are going is zero.
To an outside observer, time stops for the people in the spacecraft.
At any rate, it's also theoretically impossible to go the speed of light. You'd need infinite energy.
