ASRock Z77 Extreme4
all consumer motherboards have an ethernet port to connect to the internet. Some even come with WIFI built in. The motherboard you linked has an ethernet port so youre good to go unless you want wireless.
Yeah i was hoping to go wireless.(Should have clarified) Can you recommend a reliable network card if it doesnt have built in wifi?
Your wireless network is only as good as your router is. Depending on how old your router might be, it might be able to support N draft. As for wireless card, any brands would do as long as both router and wireless card supports N draft. I would usually go for D-Link or brands that are cheaper to replace instead of focusing on 100% reliability. For the average user, Linksys isn't necessary.
