I built a new computer last week PCPartPicker List & it ran fine.
Installed Windows 10 Pro on it. All settings were STOCK.
Today I was running "Guns of Icarus" & the computer randomly turned off. Computer won't even turn on at all.
No POST no BIOS, nadda
I've troubleshooted the following:
Power switch did nothing. Reset button did nothing. I unplugged PSU, plugged it back in. Still nothing.
The motherboard LED's light up teal & then slowly fade in & out dark blue. Dr. Debug doesn't show anything.
I checked with a flat head screwdriver to see if power switch as defective but it didn't do anything.
I reinstalled the two RAM sticks multiple times as well.
Checked the PSU with the paperclip trick - the Fan turns on fine.
I seem to have similar issue as this Reddit thread here
It's been less than 30 days since I ordered it from Newegg. Should I RMA the Motherboard?
I haven't:
Used a different PSU as I do not have one available that has a 8 pin. old PSU only has a 6pin & 4pin...
Checked voltages on PSU as the fan turned on when i did the paperclip trick Per Seasonic's website....
Installed a different GPU as I would need to ask a friend to disassemble his computer to try that..
Installed a different CPU as I do not know anyone with an AM4 socket CPU.
I'm open to suggestions! Thanks.
I haven't:
