I was just wondering what people are using to get max performance out of their ASRock mobo's and unlocked SB chips.
I'm now using the newest 1.50 BIOS and had to change settings a bit to run at the same 4.4GHz as with the original BIOS.
After playing around with much of the options this is what I have stayed with. I did not make any changes to the CPU settings under the Advanced settings menu.
Auto Overclock 4.4
Enable PLL set to 1.627
Core Voltage set to Offset Mode +.035v
LLC set to Auto which is always shows Level5
Results in about 1.6GHz@1.0v@30c idle and 4.4GHz@1.3v@70c load
My idle voltage seems to fluctuate quite a bit and I'm not sure if thats bad or not. So what's everyone else doing with these settings? Are you changing or even using any of these settings? Thanks..
Auto Overclock 4.4
