Asrock P55 Extreme / Deluxe question
MadScientist
2,183
63
I believe that the Pro, Deluxe, and the Extreme have very similar or identical bioses. About 2 or 3 bioses back on the Pro, Asrock added more options to the Dram voltage. Mine goes down to 0.998V and has a 1.348V setting.
If you are planning on heavy oc'ing, vcore >1.40V, I would go with a Gigabyte or Asus P55 MB.
nipplefish
399
Thanks for the reply. I'm not too concerned with major overclocking. For now I'm probably just going to reduce the memory timings a bit. I'm more interested in the price and the ability to mount a 775 cooler. This board seems to have all the features of a $50 more expensive board from Asus. Reviews have been pretty favorable from what I've seen.
