- Dec 31, 2005
- 5
- 0
- 0
new computer currently building:
AsRock 939pin Dual SATA mobo (ULi chipset)
AMD 64 3200+ (90nm)
Thermaltake 430w PSU
1 GB Patriot 400DDR
XFX geforce 6600 GT AGP (not PCI-E. does that have something to do with it?)
That is all that's in there, I'm just trying to get it to POST. I had everything plugged in right and when I hit the power switch all the fans would twitch. I proceeded to curse for about 15 minutes. Then I simply unplugged the 12V 4-pin power connector (that came attached to the 20 pin main power connector) and it will POST. My motherboard manual reads:
"Please note that it is necessary to connect a power supply with ATX 12V plug to this conector. Failing to do so will cause power up failure"
What's everyones take on this? Should I just keep running it without the 4V? Is that safe?
AMD 64 3200+ (90nm)
1 GB Patriot 400DDR
