ASRock Extreme 4 Z87 not booting USB device....
wotan
37
I'm building a new PC and here are the specs:
ASRock Extreme 4 Z87 Motherboard
i7 4770k
2x8gb Crucial DDR3
Samsung Pro 120gb SSD
WD 2tb Hard Drive
GTX 295
750watt PSU
Everything went together correctly and boots up OK but I can't for the life of me get a USB stick to come up on the boot menu. I've tried all the USB ports, enabling/disabling the legacy support and IDE/AHCI modes for the SATA controller. I've tried creating a disk with Rufus (GPT vs. MBR) and I've tried creating a regular windows 8 recovery disk from another machine.
I'm at my wits end here! Help??
fralexandr
2,281
222
www.flickr.com
I'm guessing your bios is set to boot from usb?
Is your USB boot drive configured correctly?
http://www.microsoftstore.com/store/msusa/html/pbPage.Help_Win7_usbdvd_dwnTool
I think the windows 7 tool works with windows 8 too. I can't find a windows 8 usb tool.
don't have another dvd drive lying around? I have an external usb dvd drive for things like this. The first time i tried to USB boot windows 7 was a pita.
Steltek
3,309
1,046
does the drive boot in other computers?
+1
I have a couple of USB drives that won't boot on any computer, no matter how they are prepared. If you have another one laying around, give it a try to see if it makes a difference.
redzo
547
Make sure that "Secure Boot" is disabled from the system BIOS. Also, I don't know how Asrock's "fast boot" function is implemented, but it may be something similar to secure boot/uefi. Disable that also and make sure that the bios is set to boot in a "legacy + uefi" combined mode, or "legacy" only.
By pressing the "quick boot" menu button at post(don't know what key for your particular mobo/bios) it's important that the usb stick get's listed there as a bootable device option. If it's not present there, it won't boot.
It doesn't matter if the usb flash/hdd is properly created for booting, it should still show on your device boot list. That is mandatory! Otherwise it will never work.
