Asrock Dual-Vsta on board sound problem
blast2blaze
Hi, im new hear and as my gift to you guys is this question...
I just finished building my computer, and my motherboard is Asrock 775Dual-Vsta, I installed the drivers, which was sorta annoying but the device manager shows everything in running, BUT when i go to control panel > sound etc... it shows that I have no audio source, I plugged my speaker in lime wire to lime input obviously and connct the power, but nothing.
Do I have to enable on board sound in the Bios, because I cant find no such option. Any help?
Thanks in advance.
Harvey
Administrator<br>Elite Member
67
The green (lime) connector is for your speakers, not your sound source. An audio source would be a CD/DVD ROM player, a microphone, an external device, such as an external player or a MIDI source.
Check your manual for BIOS settings. It should be listed if the setting exists.
Hope that helps. :)
