Scorpionwasp
Hello, I have recently assembled an Asrock A320m Pro 4 with Ryzen 5 2600, GTX 1050, single Kingston HyperX 2400 CL15 8gb RAM; system drive is a Kingston SA400, and I have a couple older 1TB HDs (Seagate Barracuda and Western Digital).
Uefi is updated to the latest (5.50) and I have no interest whatsoever in overclocking. Running a clean, formatted install of Windows 10 Pro.
I'm having 3 issues with it:
1 - The manual says a single ram chip should go into slot A2, but it won't post that way; fans reset every 15 or so seconds. System works if I put the chip into B2, which theoretically should only be used in dual chip configurations. Does this mean slot A2 is damaged, or is that just a documentation error? This is the boondocks and I can't get a second chip to test...
2 - This is the most serious issue... BSoDs. The system starts out reasonably stable, and as I go about installing updates and drivers, it gets worse, progressively. At first a couple BSoDs a day, only "IRQL not less or equal than" as an error message, system restarts. Before I know it, it's hitting every 20 mins, some 6 different error messages, sometimes it freezes when the counter reaches 100% and won't even post a minidump. It happens regardless of workload; in fact the PC is idling or doing very light browsing most of the time.
3 - Another very strange phenomenon: some boots seem to... well, to go "sour". As soon as the system finishes loading, the performance is so atrocious you can't use it. Scrolling a browser or clicking a menu item will take 2-4 seconds before it'll even register. Rebooting the system will usually fix the issue, and sometimes, a boot that started unaffected will go sour after some time (completely random). Process Explorer doesn't show anything that would justify this behavior, everything appears to be idling.
I don't know what to do at this point. NewEgg has some very bad reviews of this board, but on Amazon it seems to be well liked. Maybe they just got a bad batch? MemTest86 thinks my RAM is fine after 5 passes, but maybe I haven't tested extensively enough? I ran stress tests on all components in BurnInTest 9.0 and everything passes with 0 errors. Motherboard is the only thing you can't test directly after all...
How should I go about identifying the culprit?
