Asrock 775DUal 915GL problem
sagargv
Hello,
I have asrock 775dual915GL mobo. I updated the BIOS from 1.10 to 1.30 trough windows . All was fine. Now i observe that the games NFS UG2 and Prince of persia Warrior Within dont work . (they give 2fps , unplayable , have to press ctrl+alt+del and end task) . PLZ note that i use the given onboard gma900.
What should i do ? Before update all was fine. Also , even after update other games and things are fine. Any solution ? PLZ HELP
Thank U,
Sagar
Does no one have ans ?
SO THIS IS THE UNANSWERABLE Q IS IT ?????????????????????
should i have to post it with a diff name ?
When you update the bios, settings typicaly go back to default, so you probably need to change a bios setting somewhere, like perhaps your GMA was using more memory before the bios update, but is using a smaller amount now.
