Aspire X-Qpack cooling question
mrwabam
97
Hello All,
Just ordered my rig from Newegg:
Aspire X-Qpack for a case
http://www.newegg.com/Product/Product.asp?Item=N82E16811144160
CPU:
AMD 64 3700+
http://www.newegg.com/Product/Product.asp?Item=N82E16819103539
Hard Drive:
Western Digital Raptor WD740GD 74GB 10,000 RPM 8MB Cache Serial ATA150 Hard Drive - OEM
http://www.newegg.com/Product/Product.asp?Item=N82E16822144160
Ram:
Patriot Signature Series 1GB (2 x 512MB) 184-Pin DDR SDRAM Unbuffered DDR 400 (PC 3200) Dual Channel Kit System Memory - Retail
http://www.newegg.com/Product/Product.asp?Item=N82E16820220037
Gonna be using onboard sound/video to start.
Pioneer a110 or something from another machine for the DVD burner
I realize the ram isn't Ideal, i just wanted to see how much I like the rig before attempting to overclock....
Anyways...
What type of Cooling will I need for this sytem? In the other micro-atx machines I've bought in the past they came with pretty good replacement fans/heatsinks for the CPU. Do I need to pick one up? If so which one?
Also, how hot do the Raptors run, should i be looking to upgrade all the fans in the case?
Zap
22,377
7
Use the retail box HSF that came with the CPU. Fans in case should be fine unless you're a "quiet" fanatic. RAM should be perfectly fine. What motherboard?
VballCoach
897
I built a rig using that case. oem fan should be fine as Zap has said. I was disappointed with the carrying handle...really flimsy. I read some reviews and they all said the same about the handle. The case stays pretty cool. It's light until you load it up with your gear.
I do wish that the paint was clearcoated though.
Zepper
18,998
There are lots of threads here on the X-QPack/Chenming 118 - some good ideas there.
.bh.
VisionxOrb
113
Im using a Zalman 7700cu in my aspire x-Qpack, it bearly fits but still fits! ( foxconn geforce 6150 ekrs motherboard, 3800x2 @2.5 )
Also you might want to looking into a phyiscly shorter optical drive so you can fit a better ATX powersupply down the road. lite-on and benq are shorter drives ( personally I went with a benq)
