Hello All,
Just ordered my rig from Newegg:
Aspire X-Qpack for a case
http://www.newegg.com/Product/Product.asp?Item=N82E16811144160
CPU:
AMD 64 3700+
http://www.newegg.com/Product/Product.asp?Item=N82E16819103539
Hard Drive:
Western Digital Raptor WD740GD 74GB 10,000 RPM 8MB Cache Serial ATA150 Hard Drive - OEM
http://www.newegg.com/Product/Product.asp?Item=N82E16822144160
Ram:
Patriot Signature Series 1GB (2 x 512MB) 184-Pin DDR SDRAM Unbuffered DDR 400 (PC 3200) Dual Channel Kit System Memory - Retail
http://www.newegg.com/Product/Product.asp?Item=N82E16820220037
Gonna be using onboard sound/video to start.
Pioneer a110 or something from another machine for the DVD burner
I realize the ram isn't Ideal, i just wanted to see how much I like the rig before attempting to overclock....
Anyways...
What type of Cooling will I need for this sytem? In the other micro-atx machines I've bought in the past they came with pretty good replacement fans/heatsinks for the CPU. Do I need to pick one up? If so which one?
Also, how hot do the Raptors run, should i be looking to upgrade all the fans in the case?
CPU:
AMD 64 3700+
Hard Drive:
Ram:
Anyways...
