Aspire atlantis and sub ohm battery my impressions
Status
Not open for further replies.
Bman123
3,221
I've been vaping for 9 months now on a 900mah ego battery and aspire maxi tank with a 1.8ohm BVC using 24mg E juice, today I got my atlantis and sub ohm battery in the mail.
The new setup is barely taller then my old one but much heavier and thicker around. The drip tip on this tank is a monster, it really is huge
I knew I would need to drop down the nic level so I got a bottle of 9mg 80vg/20pg and loaded her up. The tank held close to 3ml after priming the coil, filling it and letting it sit for a half hour taking primer puffs along the way and topping it off.
The first air hole for me produced a much warmer vape and I didn't care for it but it did produce thick clouds of vapor and the flavor was really good. The second airhole was less warm then the first, flavor was still good and vapor production increased but it seemed thinner. I went to the biggest airhole and it sounds like i'm sucking air thru a straw. The vape itself was much cooler, I could take a much longer draw this way and produced a gang load of vapor, I highly prefer this air flow setting myself as it was easier on my lungs and throat
The flavor of my juice is so much better now then my old setup. I can't believe how big of a difference it was, totally night and day. I will say this tho I went from 24mg to 9mg and I need to go lower in nicotine. I am gonna try 6mg next
Overall I am very impressed with this combo and glad I purchased it.
So if anyone is interested in any e juice let me know, I have at least 3 bottles I need to sell, 2 are 10 ml bottles of 12 mg captain crunchberry, strawberries n cream the other is a 15 ml bottle of 18mg ecto cooler which tastes just like the drink form the early 90's
z1ggy
10,010
66
Vaping means something totally different to me....
What is this "juice"?
JM Aggie08
8,434
1,036
Propylene Glycol + Vegetable Glycerin + Nicotine + Flavoring.
Ratios of all 3 can vary based upon personal taste and preference.
z1ggy
10,010
66
Can I substitute the nicotine for some other product that grows out of the ground?
:ninja:
corwin
8,644
9
People take this shit entirely too seriously...just light up a joint like the good old days:colbert:
Phoenix86
14,644
10
:ninja:
I believe so, but I'm completely unsure if that type of discussion is allowed for... reasons. Google is your friend.
mnewsham
14,539
428
Which is why I added the ninja. I like Google. I will consult him later.
They make vaporizes specifically for weed, either wax or flower form.
If you wish to use an ecig vaporizer for weed you can make a THC tincture and add that to your PG/VG mix. However there is no easy way to directly use an ecig for weed.
And with THAT, the OP would like to get his discussion back on track.
Perknose
Forum Director
Status
