ASPIRE 600 WATT POWER SUPPLY
w00t
5,545
get a good respectable brand high wattage doesnt matter unless you need it make sure it has good rails i highly recommend getting a seasonic s12 series.
athens101
im going to order this system tomorrow and i wanted to know wat u think about the power supply. im buying all my parts from newegg.
250gb sata seagate hard drive
logitech z5500 speakers
bfg 7800gtx graphics card
thermaltake va3000 case
nec dvd burner nd-3520a
4000+ amd processor
windows xp pro
intergrated sound
Feb 17, 2005
4,300
fortron 450w for $50 if you're on a budget. tagan 480w u22 for $90 would power that system with no problems at all.
Insomniak
Banned
Sep 11, 2003
4,836
I'd recommend against it.
See my thread Here for the reasons why.
Cliffs:
- Replaced a 460W Enermax with that Tagan.
- 12v rail was running 11.6 down to 11.3 or lower under load.
- System was flipping a sh*t with stability.
- RMA'd the Tagan, put the Enermax back in, all was well.
Feb 17, 2005
4,300
newegg customers tend to put down reviews as soon as they get it just to rave about the shipping. it's only until a few months later when it fails and they cannot make comments. you shouldnt be buying expensive items based off of customer reviews, but leaning more to testings from well known sites such as anandtech, tomshardware, etc.
MustISO
12
I have an Aspire 550W PSU (might be the 520w), anywho, it's been extremely stable for me. No problem at all. My Antec on the other hand... well it blew once the warranty expired.
Ike0069
4,276
Actually, Aspire makes fairly decent PSU's. Definitley not great, but there are many worse brands out there.
The 550W that comes with their X-Navigator cases has received positive reviews when sites review the case.
It seems their low end models are pretty much crap, but that's why their so inexpensive. Their upper-end models seem to be much more reliable.
w00t
5,545
shouldn't jump to an s12 very quickly without even knowning the specs of his pc and budget.
ummm ok like his system uses more than 300W? highly doubt it.
edit: i was right.
yo op get the 3700+ cheaper not worth it unless they are the same price.
seasonic s12 is a very good psu check out toms hardware guide stress test plus its quiet.
BigCoolJesus
Banned
Jun 22, 2005
1,687
Originally posted by: athens101
the seasonic ps has worst reviews than the aspire i was going for originally
No, Seasonic >>>>>>(OWNS)>>>>> Aspire
and by own, i mean like how a bus would own a possum
Feb 17, 2005
4,300
edit: i was right.
ok i quoted you because you randomly stated the s12 without knowing the system, now you are quoting my statement about your quick suggestions, saying something about his sytem using more than 300w? you're very confusing.
