- Feb 5, 2001
- 873
- 1
- 76
Im trying to use a Artiscan 1100 scanner on a propriatary printer PC running Win NT.
I have installed Scanwizard and SCSI controllers on 4 previous systems with no problems.
The scanner and controller work fine as I just used and retested them on another system right next to it.
Yes it uses Win NT, The printer software will not run on anything else and is propriatary.
What is happening,, Installed SCSI card, Installed the drivers, SCSI devices shows the card and the scanner hooked up all looks good.
Install Scanwizard, Nether it or the SCSIprobe will run (Maybe get hourglass or a blip on the taskbar), If I uninstall the SCSI driver they will run but cannot find the scanner.
I have tried various version of the SCSI controller drivers and the ASPI drivers, Even old versions as rumor that might be the problem but still the same exact problem.
I have tried older version of the scan software also.
In my opinion it seems to be blocked at the ASPI driver in some way.
I really need help on this, As without it it makes an expensive printer usless.
I really hate NT.
I really hate NT.
