asp help!
fishy101
Hi,
I have a Access database where the records in there are hyperlinks, and I am trying to make an asp page such that I can pull the each record off the database and have it be linked to whatever it is linked to in the Access database. I have tried to simply use response.write(), but did not write anything to the asp page. Anyone know of a good way to do this? Thanks in advance.
Leon
Download a trial copy of Drumbeat 2000 or UltraDev from Macromedia's website, then you can do it with no coding at all. Or you can check out this site http://www.aspin.com/, they have a list of forums specifically for ASP questions.
well, if you're working with asp, then you probably know some html.
you just call the same record again and include it into the <a> tag?
You can do this:
Set the record in the database to a variable
In the HTML code write: <A href=&quot;<%=variable%>&quot; target=home>text</A>. This is for if the record is just an url.
Or if the record in the database is the whole href tag, then you can just do the same but type out <%= variable %>
