- Jun 22, 2020
- 11
- 0
- 36
Hello everyone
The OS is Win10
The file-system (also on the External hard disks) is NTFS.
I NEVER had this problem, even with very long filenames.
Third party apps (even Microsoft's PowerRenamer) don't help with this problem (anyway, now the filenames are short).
I've scanned both the PC and the external HD, repeatedly, with a few apps. All clear.
I used to have the same problem on computers' main drives, but a simple registry tweak (that I found online) had solved the problem on the PC. Regarding External drives, Google finds absolutely NOTHING on the internet.
I've got truckloads of items saved onto External hard disks.
After lots of work on my part, their filenames are short.
Even so, very often, I cannot rename them, or easily move them, etc.
Such files are NOT nested inside subfolders etc etc
The problem persists even if/when I move files from the External HD to the PC's C-drive.
I often get this weird Windows message::
"If you change a filename extension, the file might become unusable. Are you sure you want to change it?"
The thing is, I'm not touching, at all, the file-extension. I'm only trying to shorten (a little. or a lot) the NAME of such file(s).
What's going on??
In advance, thank you very much for your help
Christian
What's going on??
Christian
