ASIO-capable sound card that's cheap and OK for gaming
Howard
47,982
11
Any ideas? USB is preferable, but I don't mind PCI too much.
I only need ASIO for two channels, if that makes any difference.
Modelworks
16,240
7
Originally posted by: Tiamat
Originally posted by: Modelworks
ASIO and USB and spdif all for $30
http://www.americanmusical.com/Item--i-BEH-UCA202-LIST
How does this compare to the 100$ EMU 0202 in sound quality and ability to push headphones?
I can't say since I don't own either.
But the specs on this one are:
Phones out : -2dBu, 2x3,7 mW @ 100 ohms
DAC: 16 bit 32Khz, 44.1Khz, 48Khz
Freq. response: 10 Hz to 20Khz +- 1dB
THD: .05% @ -10dBV, 1Khz
SNR: 96dB
not great but not bad either for the price.
Modelworks
16,240
7
Originally posted by: The Boston Dangler
Phones out : -2dBu
i'm not familiar with the u weighting
It means unloaded
dBu can be used regardless of impedance, but is derived from a 600 O load dissipating 0 dBm (1 mW).
I wouldn't recommend that unit for people that use high quality headphones, even under the best conditions 7mW is really low power.
Mar 10, 2005
14,647
Asus Xonar U1
this is based on the c-media xonar chip (2.0?) and google leads me to believe it supports ASIO 2.0. there are pci and pci-e versions available, and it comes in 6 snazzy colors. newegg has the white one for $90.
i've been using a c-media based card for several years, and couldn't be happier with it. the software is very simple and stable, and DDL/DTS encoding works seamlessly. in 3D games, it's absolutely superb.
