- Apr 25, 2003
- 380
- 0
- 0
Is Artic Silver 5 is the best thermal compound to use currently? Or is there a better one out there? Can you guys recommend any brand ?
Originally posted by: mpilchfamily
The diffeernce between the differnt thermal compounds is only a couple of degrees at most. Often it comes down to how you apply it. too much and you may not be getting the full benifits of the compound.
