As cheap as possible case for secondary rig
Discussion in 'Cases & Cooling' started by Smartazz, Nov 8, 2012.
  1. Smartazz
    Smartazz Diamond Member
    Dec 29, 2005
    6,128
    Hi all, I have a Q6600 and all the parts lying around for a secondary rig. The case needs to have room for an ATX motherboard, a Tuniq Tower and a 6870. I have two 120mm case fans that I can also add to the case. Any recommendations that are very cheap $50 tops would be appreciated. Thanks.
  2. Loading...
    Similar Threads - cheap case secondary Forum Date
    Cheap, yet surprisingly good, fluid dynamic bearing case fans!? Cases & Cooling Feb 24, 2017
    Cheap case for water-cooling. Cases & Cooling Jan 22, 2017
    Best cheap system-builder micro-ATX case / PSU? Cases & Cooling Apr 4, 2016
    Ideas for cheap 'filter' material that can be cut to fit case fans Cases & Cooling Dec 9, 2015
    Cheap case with plenty of room Cases & Cooling May 3, 2015
  3. crazymonkeyzero
    crazymonkeyzero Senior member
    Feb 25, 2012
    363
    My recommendation would be the Antec One. It is probably the best, full featured mid tower you can buy for under $50. Great clearance for large heatsinks, and also good ventilation and cooling design for fans.
    A slightly cheaper alternative is the NZXT Source 210.
  4. kleinkinstein
    kleinkinstein Senior member
    Aug 16, 2012
    823
    Ahhh c'mon, for $50 shipped you need a windowed Lian-Li to show off that Tuniq Tower. I still have mine. What a classy classic! Or you could just go super el cheapo and snag a $15 Gigabyte box.
  5. Smartazz
    Dec 29, 2005
    6,128
    Wow, that Lian Li looks great. Will I find it that cheap usually?
  6. kleinkinstein
    Aug 16, 2012
    823
  7. Eureka
    Eureka Diamond Member
    Sep 6, 2005
    3,828
    The NZXT is the cheapest case now, I believe ($30AR). I've seen some as low as $15 but those are few and far between.
  8. Smartazz
    Dec 29, 2005
    6,128
  9. blastingcap
    blastingcap Diamond Member
    Sep 16, 2010
    6,656
    I got a free-after-rebate Diablotek case that seems to be working okay. I wouldn't use it for high-performance gaming or anything, and it came with broken "tool-less" plastic bits and no side or top fan mounts, but I can't really complain, given the price. Also, it fits a Hyper 212+ cooler which is unusual for the really cheapo cases. So maybe just wait for a sale on some crappy case.
  10. lehtv
    lehtv Elite Member
    Dec 8, 2010
    11,799
    51
    NZXT Source 210 $30AR
    CPU cooler clearance 160mm so it'll fit the Tuniq Tower
  11. Smartazz
    Dec 29, 2005
    6,128
    Is Antec usually good with mail in rebates?If so I'm going to order the Antec 300 for $35 after mir later today.
  12. Smartazz
    Dec 29, 2005
    6,128
    A good deal, but I bought the Antec 300 for the same price. I wonder how it'll compare to my 1200, I assume not quite the same quality given that I bought this case for $170 years ago.
  13. lehtv
    lehtv Elite Member
    Dec 8, 2010
    11,799
    51
    Antec 300 is sturdier than NZXT Source and has an extra fan, but NZXT Source has better cable management, black interior, more space and a bottom PSU fan intake area
  14. sigmas
    sigmas Junior Member
    Nov 14, 2012
    nice to see all comments :p
  15. Smartazz
    Dec 29, 2005
    6,128
    Pretty impressed by the Antec 300. Haven't had the chance to build the computer but the build quality is great for $30. Makes my Antec 1200 look gigantic too.
