tonytoronto
Hi everyone,
First post, great site.
Finally have my p5b-deluxe wi-fi working good, except for one last issue, if i enable Q-Fan to control the CPU fan (Artic-cooling Freezer7 pro) the rpm will always be around 640rpm, since the minimum is 800, the BIOS starts complining and gives me a low rpm message, i have used all 3 settings in Q-Fan and always get the same result, anyone with the same issue? Is there a workaround? Right now i have q-Fan disabled and fan is spinning around 2600rpm, the CPU is cool but it's bit noisy, i'm sure something around 1200rpm would keep it just a s cool. I have the latest Bios and had the same issue with the OEM fan.
Q-Fan finally works good on the Chassis Fans, they spin around 1000rpm and are really quite with tons of airflow.
Thanks
p5b-deluxe wi-fi
6300 Core2 duo
xfx 7600 gt
2Gb OCZ 6400
Enermax Liberty
Thanks
p5b-deluxe wi-fi
6300 Core2 duo
xfx 7600 gt
2Gb OCZ 6400
Enermax Liberty
