Artic Cooling Pro2 L
Weeeman
Wont Spin In Medium/Low Speeds! As the summary says, works wonders in high.. but i dont need it in high! Is this a common problem for these fans or just me?
If this is one of the temp controlled fans, get the temp sensor further away from the heat source. I.e. if it's on the heatsink make sure the sensor doesn't touch the heatsink itself.
Nah it just has a switch on it.. it runs very well on high.. but its going to be close to my ear.. so i want it on low if possible.. but it just doesnt spin.
