Today I bought an XFX 8800GTX.
Rest of my system:
A64 3700+
1GB DDR400
ASROCK Dual-SATA2 motherboard
XP Pro SP2
DirectX 9.0C (latest one)
When I got it home I realised that I did have 2x PCI-E connectors, but they were on the same wire from the PSU - which the XFX leaflet says won't do. My PSU is some Thermaltake 550W one, can't remember the name (could have been purepower, toughpower or something).
As it stands, I'm running the card on both of those, since the shops were closed and I couldn't get hold of a 4-pin molex to PCI-E adaptor. I have tried playing Oblivion and FEAR - both of which work initially, but develop artefacts after a short while. The HUD, text and mouse pointer get all blocky and messed up on Oblivion, and on FEAR everything turned bright pink.
Then, after I tried to quit Oblivion, my screens went to 640x480 and I got a dialogue box saying that nv4_disp.dll or something similar was not functioning properly and that I should reboot.
That was using the 97.44 official drivers, I've also tried uninstalling them and using the 96.89 drivers that came with the card. I did not experience the same artefacts, but the game did still show the occasional flash of mangled geometry and it crashed after 5 minutes, freezing my machine.
It might also be worth mentioning that none of my system is overclocked in any way.
I am assuming this is because of my running it without the proper power setup - can confirm whether this is likely to be the case? They say it is okay if you just use 2 separate wires from the PSU, do you think that my using a separate wire with a PCI-E adaptor on it will solve the problem?
Thanks.
Rest of my system:
A64 3700+
1GB DDR400
XP Pro SP2
Thanks.
