Arsenal of programs to help fix others' PC problems
IS300
Even though I know little compared to most on these forums, lately more and more people have been asking me to come over and help "fix their PCs."
Typically, these problems are:
- Have virus/malware issues (almost always)
- Cannot connect to internet
- Computer seems really slow.
I'd like to have a arsenal of tools that I can carry around on my flash drive (sometimes their computer is unable to connect to internet), so that I can help solve their problems with minimal waste of time.
From several helpful posts in theses forums, I've found a couple programs and/or helpful instructions:
In particular, this link seems to be very helpful (thanks law9933).
Also, MechBGon's page on How to secure your PC is helpful.
Here's a list of programs I've come up with so far:
A copy of Windows XP (just in case all else fails, assuming they have their code)
Hijack This (although this will probably entail ALOT of time spent uploading logs, etc.)
Avira Anti-Vir Free
Ad-Aware SE
Spybot S&D
SpywareBlaster
Belarc Advisor
Thanks for the acknowledgement, I thought 1972vet was to the point but there are similar postings.
What you have is all good, Blaster is a protective blocker after the PC is fixed.
What one might miss another could find, these are also free.
AVG Antispyware
SUPERAntispyware
a-squared
ATF cleaner or CCleaner (Issues is a safe registry cleaner) I don't remove prefetch or cookies with passwords.
SysSpec
What's Running
Startup Inspector
Silent Runners
autoruns
WinPatrol
BootSafe is handy if XP runs
A disk like Linux Ubuntu live CD is handy to determine if it is a XP crash or hard drive problem.
I am only a amuture also, all I know is from studying the pros on the forums.
Nothing is better than a HJT advisor's knowledge.
There are online HJT analyzers I use for a quick check, but they are not to be trusted.
