- Jan 16, 2001
- 816
- 0
- 0
My pc was running fine for over a year with a FX 5600 in it. I booted it one day and found the monitor was staying in sleep mode and the BIOS screen wasn't even coming up. I checked the card/cables and still had no luck. I put in the original system's Geforce 4 mx and it ran fine and I decided the card must have failed and got a new one to replace it anyway. I put a new 6600 card in, ran for around a month with no problems. Then it did the same thing the other card did, boot pc, no bios loading, monitor thinks it is in sleep. I tried attaching a different monitor but still the problem continued. I removed everything from the system and tried booting with one of the two new cards and had no luck.
So now I am sol as the return period for the new card is gone. I even bought a brand new 500w PSU thinking it wasn't getting enough juice to the cards. My question is why does the PC run fine with the Geforce 4 mx and not with the 5600 and 6600 (both different brands btw).
What should I do? My pc is still under warranty but the original card works fine but not the new ones. I don't overclock my components so I don't think it is heat related.
Help! I need my gaming fix
