- Dec 29, 2002
- 7,402
- 0
- 71
My monitor is driving me nuts...at least the drivers are...driving me nuts...
I mean, it seems like everytime I change the resolution or do something related to the monitor, it uninstalls it self or something and i'm stuck with "Default Monitor", and not "NOKIA 445PRO" like it should be, then i try to "update driver", and it says it can't detect my Nokia Monitor. Though if i go to the Monitor Properties, it identifies it as a Nokia 445 pro, which is correct, but i click the Monitors tab, it only shows "default monitor". Then i'll reboot and everything will be fine again. It's annoying that it keeps changing, any ideas how to fix it?
