Okay here's the situation, i have 4 serious problems that are really upsetting me, and I can't figure them out for the life of me.
1.) FOr starters, from the day i bought my Intel 2.26 brand new straight from Intel, packaged and everything from them, i have not been able to run my cpu at 2.26. I have had to keep it at 1.8 or lower. Why? Because when i try and run it at its stock speed, i get even MORE problems, from games like Warcraft 3 (Fatal Memory Error), and other games as well. Perhaps that's a game issue, but honestly i dont see why when i run my cpu at 1.8 most things work fine (Not including the problems below), but when i run it at 2.26 my games go to hell? (Freezing, Memory Errors, etc..) I bought the 2.26 to O/C and ive had to U/C just to get it to work! I'm using the stock heatsink and fan that came with the CPU and i even used Arctic Silver paste to help the heat transfer. On top of that, i have a 500 w p/s, a good one Enermax i think, and i have about 5-6 fans running in the aluminum case, not to mention the 2 on the pow. supply. I check my cpu volts and temp and everything seems to be normal. So as much as i think and want it to be a heating issue, i just can't imagine how it could be? What other reasons could it be that running my cpu at stock speed gives me problems?
2) Very often, if my computer is recovering from a crash of some sort or other, and i have to manually reset, my computer will restart, but the monitor will go into i guess "Standby" mode. THe light will turn from green to orange and i won't have any picture, nor does it sound like my computer is even booting past the Bios information. It's on and running, but there's no windows loading or anything, and the screen is blank with an orange light!! I have to turn the power switch in back of the computer off for about 10 min, then re-start and it comes back up normally. THis as been happening since the day i built it, and i have no idea why. WHat could it be? I dont think it's a monitor problem just so ya know. Monitor works perfectly besides this.
3) This problem started happening a few days ago. I'll be playing a game Like Halo or Command and Conquer, and sometimes even when im just multitasking IE, or something else, my computer will go on the fritz and starts making interval pauses, where the screen freezes, and the sound stutters for about 20 seconds, then it will let up for about 15 seconds and then freeze/stutter again. It will continue to do this until i reset the computer, at which time i will usually get problem # 2 up above when i restart. THis doesnt' always happen during games necessarily but i think it's happening during resource heavy applications, like games or when i have 5-6 programs opened at once. This only started happening recently, when i started installing some new games i got, and started watching some dvd type movies on my computer.
4) Lastly, this has also only started happening recently, but sometimes after problem #3, then #2 happens, i will get THIS problem. When windows finally loads properly, it will load up and as my task bar items are coming up, the screen and computer will freeze. THe strange thing is, the mouse cursor always disappears. It just blinks out of existence, and i cant even give the computer the ol 3 finger salute to restart. I have to manually do it incuring problems #2 and #3 all over again sometimes. It's like 1 never ending problem. I need some serious help here. These seem to me to be either Video, Ram, or heating issues, but i'll give my specs below and you'll see that i should have adequate equipment to not have these problem keeep occuring.
Any help would be GREATLY appreciated. Thanks. My system SPecs below:
Intel P4 2.26 533 mhz
512 mg Corsair XMS 3000 Ram (1 stick, i have tried other slots to see if it fixes problems. It does not)
75 gig IBM hd (on another note, until about two weeks ago this only had 20 gigs full, now i have about 50 or so full)
ATI Radeon 9700 Pro (with the latest 3.9 Catalyst Drivers, it's not Overclocked at all)
IBM p70 21' monitor
Logitech MX?? cordless mouse
Hercules 6.1 GameTheater XP (with latest drivers)
Asus P4b533 MOtherboard with latest Flash bios
WIN XP Professional with SP1 and all that garbage
SOme games i run:: Warcraft 3, Halo, C&C Generals, QUake3, Counter-Strike, etc..
Just to answer any questions regarding this, i have updated every piece of hardware with the latest drivers.
Also i'm using Intel's Accelerator. I have no idea what this really does, but ive used it since the first day i put my machine together, i think it was an update with my mobo or something. I dont know if this could cause any issues but i thought i'd mention it anyway. Thanks for any help
Should i add more ram? Try to cool the CPU down more? Take a hammer to it? HELP!!!
-Justin
