Originally posted by: bamacre
What about this one...?
http://www.bfgstore.com/Produc...uctCode=PCIXPRESPWREXT
I would think it to be safer to use a 6pin to 8pin adapter rather than two 4pin molex to 8pin adapter.
I would rather get the 2xMolex to 8-pin than the 6 to 8 pin PCIe connector,
The molex will probably be more efficient in supply the enough power, especially if you go between 2 separate 12V rails.
The 6 to 8 has a disclaimer:
NOTE: Connector should not support more than 108W. The 8-pin connector does not support +12V sense function.
Even not knowing what it means, I would not take a chance with the ordinary 6 to 8 pin...![]()
Originally posted by: DerekWilson
you don't want to run one card off multiple rails -- if you plug two rails into each other like that you end up connecting their common ... which can cause instability. i think that's part of why we are seeing the move to single 12v rail PSUs these days ...
using these kinds of converters is a little touchy some times. it may or may not work depending on PSU and system ... I wouldn't recommend it for things like SLI, but you can probably get away with it with most single card setups.
