Arggg I suck at math... Help please!
Vortex22
4,976
Ok, I'm stuck on these two algebra problems.
This one looks incredibly simple, but I can't figure it out:
Find a negative solution of x^2 = -23x + 60
It looks like a quadratic, but the answer I get when I plug it into the quadratic formula is incorrect. (this is online homework btw, I don't know the correct answer, I only know that I'm wrong :( )
And the other one is 11/x-1 + 9/x+1 = 1/x^2-1, where x is in the form A/20, I have to find A
Note: the last denominator is x to the 2nd power minus 1, only the 2 is an exponent.
I multiplied the 1st fraction by (x+1) and the second by (x-1) and got a final answer of A=3/20 but this is incorrect. I probably look like a total moron, but I hate math :p
I usually figure this stuff out on my own, but I can't get these 2 for some reason.
Thanks in advance for any help
dighn
22,820
4
It looks like a quadratic, but the answer I get when I plug it into the quadratic formula is incorrect. (this is online homework btw, I don't know the correct answer, I only know that I'm wrong )
it is quadrtic. change it into standrd form like x^2 + 23x - 60 = 0 then solve like that
would be really simple if it were -23x and +60... but for this yo'l have to use the formula i think
Vortex22
4,976
I get x=-25.37 when I do this.
After plugging it into the equation I get 643.6369=643.51 :confused:
It might just be the calculator that is causing the small difference though.
dighn
22,820
4
After plugging it into the equation I get -643.6369=643.51 :confused:
x^2 cannot be negative for real x's
Vortex22
4,976
Yeah I was putting -25.37^2 instead of (-25.37)^2 into the calc. But that wasn't what was causing my problems before, I just forgot to type it like that.
Vortex22
4,976
Well, I guess -25.37 is the correct answer for #1. Thanks
#2 is annoying me even more since I actually got an answer that appeared in the correct form after working through the problem, but it's still wrong :(
Vortex22
4,976
Ok I'm not really sure how to go about doing this problem the correct way but:
11(x+1)/(x-1)(x+1) + 9(x-1)/(x+1)(x-1) = 11x+11/x^2-1 + 9x-9/x^2-1
Add the fractions since the denom is now the same...
20x+2/x^2-1 = 1/x^2-1 ... -1/20?
Well, I screwed something up somewhere since last time I did it, I ended up with 20x-2 which made it 20x/x^2-1 = 3/x^2-1, then I just divided to get 3/20.
So, umm, yeah like I was saying... I suck at math.
dighn
22,820
4
-1/20 looks right to me but dont forget that's x, you need to find A still (but that's much easier)
Vortex22
4,976
Ok the correct answer to #2 is confirmed as -1/20... I was just a moron and screwed up a sign somewhere before.
dighn
22,820
4
don't forget you said #2 is asking for A in x = A/20
oog
1,721
recognize that (x^2 - 1) = (x+1) * (x-1). multiply everything through by (x^2 - 1), and that will get rid of all the fractions, leaving you with a quadratic equation.
Vortex22
4,976
don't forget you said #2 is asking for A in x = 20/A
They just wanted the numerator as in A/20.
I put in -1 and it said correct so I'm happy :D
Vortex22
4,976
Ahh this was probably the *official* correct way to do it.
Thanks.
oog
1,721
sorry, you don't even have a quadratic equation after multiplying everyting through by (x^2 - 1)
Vortex22
4,976
Oh, thats ok... The way I used worked.
dmw16
7,608
for #2
goes like this:
[11/(x-1)] + [9/(x-1)] = [1/(x^2 - 1)]
the right hand side factors out to:
1/(x-1)(x+1)
so multiply thru by the denominator and you get:
11(x+1) + 9(x-1) = 1
11x + 11 + 9x - 9 = 1
20x = -1
x = -1/20
-doug
Vortex22
4,976
Originally posted by: Mak0602
use a TI-83+. It helps alot with these kind of problems.
We arent allowed to use any type of graphing or programmable calculator.
