Are these two types of tires interchangeable?
Techie333
2,368
I have a really old car that I am going to give away, but I have been told by mechanics that my tires need to be changed right away because they are in really bad condition. So since the old car has better tires........I have a questions.........can these two types of tires be interchanged???
New Car: Goodyear Invicta P195/70 R14 90H, Treadwear: 220, Traction: A, Temp: A.
Old Car: Goodyear Wrangler HT, M + S 185 R14C, Load C, Tread: 340, Traction: A, Temp: B
Someone who can help out please?.......also how hard is it to take tires off of rims.........do I need any special tools in particular???
PsychoAndy
10,735
well, if the tires are teh same size. r 14 in your case i dont see a problem.
BTW, i wouldnt make replacing tires a DIY job. take it to sears or something
db
10,575
292
And besides, they need to be balanced once they are remounted. Not a DIY job.
Brutuskend
26,558
4
Tires are tires for the most part.
The size being differant may throw off the speedo a bit though.
Don't even TRY changing the tires without a machine though (from one rim to another) you will NOT be a happy camper!!
Cyberian
9,999
Sounds to me like they should be interchangeable, but I would check with a Sears or Firestone type place first.
