Are these temps within range for Asus A7V --T-Bird 800 ?
ddrupp
46
Ambient temp is 25 C --Case is 28 C and CPU runs at 39 C at first boot to right now at 44-45 C as I speak on the net. I just got done playing a game of High Heat 2002 also so that may play a part also. I am using MBM 5.06 I think. I have the Taisol Heatsink with the 3 clips for the socket without the cooper bottom. I am using Artic Silver 1 and the stock Delta slim fan that came with it. Are these temps normal for the above setup with the stock fan that came with the Taisol ? And what other solutions fan wise can I put on this heatsink to help with cooling if it is on the high side ?
Thanks
Dave
eeut
92
don't know really, but, i used to have same setup like yours getting within that temp range and overclock it to 1050 w/c hit 45c idle and 50c at full load.
