With the Abit KT7A, to get a more accurate reading, you MUST bend up the temp sensor slightly, so that is is a little above the socket, then press down on CPU while lockiing it in place. This will assure a positive contact between the sensor and the CPU. If it's not touching, (like the way the board is shipped), your temp will show as lower than it really is.
On the other hand, one of the quickest and easiest ways to lower your temperature, is to push the sensor down, as far away from the CPU as you can.
