- Sep 13, 2004
- 22
- 0
- 0
I have been monitoring my CPU temps lately and I was wondering if these temps could be right. I installed motherboard monitor and it says that the temps are as follows:
Under 100% Load:
Case: 17 C
CPU Diode : 34 C
CPU Socket 53 C
Room temp is 20C / 68F
The bios reads 30 C on startup.
First off, do I look at the Diode or Socket readings?
If the Socket reading is the case then I dont think that these could be right, maybe I'm wrong. Here are my specs. Any advice would do. Thanks
CPU: AMD XP 2700+ (not overclocked)
VIDEO: X800 PRO
3 HDDS
3 80mm intake fans with 35 cfm each
1 120mm outtake fan with ~70-80 cfm
1 90mm cpu fan with ~ 40-50 cfm (pushing onto heatsink)
Thermalright SLK968U with articsilver5
plus PSU fan with unknown specs
Under 100% Load:
Case: 17 C
CPU Diode : 34 C
CPU Socket 53 C
VIDEO: X800 PRO
3 HDDS
