Are these temps normal?
MustangSVT
11,554
12
H/W monitor
didnt even o/c much because of IP35-e boot problem.
right now at 2ghz on 233fsb. stock volts.
hdds are actually really hot to the touch.
using gemin2 on the cpu but it is actually quite cool hmmm but is the temp alright?
imported_Scoop
773
Those HDD temps would indicate that you don't have and front intake case fan blowing at them? They are about 14C higher than mine, though 5C lower than what was in my old case which didn't have an intake (or an exhaust) fan. Otherwise those temps look decent since the CPU fan is running pretty slow and I take it those are CPU load temps.
What boot problem do you have? You mean the double boot? Shouldn't be a reason not to OC.
