Are these temps correct?
evenmore1
369
In the BIOS, the temps read 51 C. That seems fine. I just downloaded Motherboard Monitor 5 and it says the temps are 127 C CPU and 16 C Case. Is this really high? When I first saw it I freaked out. But it's been running for almost 3 years. So is anything wrong with it? Is this normal?
on stock
JeffMD
2,026
19
60f is a pretty cold case... is it like 50f in your room? if not, then yes that one is broken.
Your cpu is pretty much guarenteed bunk, since the athlons are pretty much fried above 90c.
evenmore1
369
wait...it still works...
should I get a different program? So 127 C is too high? The BIOS has to be accurate right?
what programs do you recommend?
Hand Ov DooM
35
Are you sure that's not fahrenheit? 'Cause that would make sense if it was.
If you were running at that temp, I think you'd be having some serious issues.
And it's not uncommon to just have a dud of a temp. sensor.
