ok i am wokring on OCing my comp in sig. i started by setting everything 1:1 and i foudn the max i could go was 217fsb. then i set a 5:6 divider and got it to 235. when i did this the temp stayed the same acording to everst. idle at 38c i am on stock cooling. does this sound like it is correct. but then last night, my comp was really loud for some reason so i check the temps. i was at 65c IDLE. so i rebooked moved everything back to stock. does this seem the be correct? thanks for all your help.
