- May 13, 2003
- 13,704
- 7
- 81
This machine will be started in a week. Parts to get it operational will be first, and then RAID and hard drives will be added as time goes by.
__________load____PSU @ 50%___PSU @ 70%_____PSU @ 90%
fans*_____78w_____156w_________110.76w________86.58w
H2O______24w_____48w__________34.08w_________26.64w
system____175w____350w_________248.5w_________194.25w
CPUs_____160w____320w_________227.2w_________177.6w
25 hds____230w____460w_________326.6w_________255.3w
total______507w____1014w________719.94w________562.77w
Components
CPU: 2 x Intel Xeon E5405
mobo: Supermicro X7DCL-I
RAM: 6 x Kingston 2gb PC2-667 ECC
RAID: 2 x Areca ARC-1230
HD: 24 x Western Digital 500gb RE2
fans: 8 x 92mm Akasa Amber; 5 x 120mm Akasa Amber
water cooling: Swiftech MCP665 pump
video: onboard
I'm looking at getting the Ultra X3 1kw PSU or Corsair HX1000, and I'd like to keep it in the 50-70% load range. This machine will be a file server and CPU usage will be at a constant 100% due to crunching Distributed Computing projects. Also (*), fan power usage was estimated as I couldn't find the actual power specs on the Akasa Amber fans.
Components
video: onboard
