- Aug 25, 2001
- 56,580
- 10,217
- 126
Are you a human?
Document Display | HPE Support Center
The HPE Ethernet 10Gb 2-port 561T adapter is a Dual-Port 10GBASE-T adapter, featuring the Intel X540 10 GbE solution in a PCIe 2.1 compliant form factor designed for HPE ProLiant Gen8 rack and tower servers. The HPE 561T adapter delivers full Line-Rate performance across all, utilizing CAT 6A UTP cabling (Or better) with distances up to 100 meters. Providing high performance Ethernet connectivity, it is ideal for virtual server and cloud computing environments.
I believe that this is NOT NBase-T compliant or compatible at all, only 100/1000/10000 Mbit/sec (per each direction, per each port).
But would these plug into a standard DIY PC AM4 mobo's PCI-E slot (x16 sized)? Nothing "funny" going on? Just load HP/Intel X540 drivers? They're under $120 for a dual-port 10GBase-T card.
