Are these frame rates good for a 9700Pro? In UT2003
BoomAM
4,546
Hi,
I just purchased a Sapphire 9700PRO, although the heatsink is an ATI one w/ the ATI label.
Anyway, ive been saving up for it for quite a while, and i wondered if i was getting what i should be frame rate wise.
Here are my results using HardOCPs UT2003 Benchmark Program.
1280x1024 High Detail Tests.
The frame rates are the averages.
DM-Antalus - 101fps
DOM-Suntemple - 105fps
DM- Phobos2 - 95fps
Dm-Inferno - 86fps
CTF-Face3 - 98fps
CTF-Citadel - 70fps
DM-Asbestos - 118fps
I tested with 3DMark2001 but got only 8400 3DMarks, so i thought, 3D Mark aint that reliable anyway, so i tested in UT2003.
Thanks in advance
WaTaGuMp
21,207
2,506
Well you are over 60 fps in all catagories dont see anything wrong. You can even drop to 40fps and its not like your eyes can see the difference. Now that I said that watch me get attacked for saying that 40 fps wont be noticable.;)
BoomAM
4,546
So i should just ignore the 3D Mark Disastor?
I Upgraded it from a GF3Ti200@Ti500 w/very old "19 CRT to a 9700PRO w/ Hitachi TFT.
Did i do this right(read below)
1) Uninstall Video Card from system propeties.
2) Uninstall Video Drivers
3) Search HDs for nVidia Files, and delete
4) Search Registary for nVidia references, and delete.
5) Switch off PC, take of GF3, put in 9700PRO, connect power cable.
6) Switch on, revert CPU back to stock speeds (cos 9700 card dont like FSB`s over 70mhz aparently)
7) Put AGP Arpeture to ATI Reccommended (128mb) was 256mb.
8) Install ATI Drivers, then Control Panel.
Anything else. Prehaps a program to completely rid my system of nVidia(just in case i missed anything)
WaTaGuMp
21,207
2,506
Hmm what I did from going from Nvidia to ATI was redo the OS. But you can try reg cleaner to make sure you did clean the registry completely. As for your scores I cant get the page up to see your PC specs I will say this I get 13200+ with my system running a P4 at 115 fsb with the Radeon 9700 pro not overclocked. THe system seems VERY picky when doing the drivers and the control panel, I reboot everytime I remove something.
I remove the drivers and reboot
Remove the control panel reboot
Run reg cleaner remove anything that says ATI
Then I install the drivers reboot
Then install the control panel
Make sure you dont remove DAO during driver installation.
Doing the OS over might be time consuming but its the only %100 way to start from a clean slate.
Reg Cleaner
SFang
655
I tested with 3DMark2001 but got only 8400 3DMarks.
I highly suggest you switch to a much better DDR motherboard than your current one with PC133 memory.
My 9700pro scored 15800 with 3dmarks2001se with A7N8X. Your CPU and especially Video card are severely bottlenecked by your MB and Memory. Change to a Nforce2 board with 256MB pc2100 ddr will almost ensure you a 13000+ performance. Old Nvidia driver may affect you a little, but only within 200 points at most.
KT7A - Raid + 768MB PC133 <=> $100 Nforce2 board + $40 256MB PC2100 DDR
will make you feel totally different. :)
BoomAM
4,546
Hi again. Ive just had to re-install windows completely(formatted c:) cos of some problems, i was goind to do it weekend anyway.
anyway, ive installed the ATI Drivers off the CD that came with the card, and im just about to DL the latest off the ATI Website.
I would upgrade to a DDR baced Mobo, but ive just bloan £700 on a 9700PRO & 17" TFT Hitachi Monitor(yes the 16ms on, mmmm) So until at least may, i wont have the money, and even then, it`ll probably be october till i have the money for a new mobo&ddr.
All is was wondering originally, was if it was a good score for my system(in ut2003).
Kazuo
145
40fps is tolerable, but I'd hardly say anything above it isn't noticeable. Especially if you see something 40fps next to something that's 80. You'll be able to tell which is which pretty readily.
BoomAM
4,546
BMW330ci, this monitor rocks.
Ive reclaimed my desk.
Image Quality with DVI = very good.
Image quality with DVI & 9700PRO = Unbelieveable
I cant stress enough how good this monitor is. Sure it cost alot compared to the equilivent CRT but, the extra room on your desk will certainly make up for it.
I cant notice any ghosting/lag/trailing. at all.
Colour reproduction is very good as well.
In case you didnt guess, im very very pleased with my purchase.
Noid
2,373
183
Here's mine ... on my AMD box with my 9700 at STOCK clock settings.
----------- EDIT ---------- 1/10/03 6:37pm CST
my XP2600+ is running 2200.6 Mhz @ 1.76v
(115Mhz oc)
11.5 x 191.3
3dMark 15,405
Cat 2.5 6218
and I just realized I cheated ... both OpenGL and DX were set on Performance
so .. If you guys want me to repost on the Balanced setting ... let me know
This is High Quality test ....
The test results are each map at different res
1st map 1600x1200
2nd map 1280x1024
3rd map 1024x768
dm-antalus
20.281128 / 89.459953 / 281.558807 fps
Score = 89.457413
dm-antalus
23.306808 / 129.142197 / 290.008362 fps
Score = 129.161591
dm-antalus
98.172165 / 177.964935 / 594.574402 fps
Score = 178.052429
dom-suntemple
20.633348 / 94.955978 / 467.891266 fps
Score = 94.983650
dom-suntemple
35.808197 / 127.651672 / 466.198151 fps
Score = 127.666870
dom-suntemple
80.133942 / 177.110962 / 493.667633 fps
Score = 177.186035
dm-phobos2
23.534763 / 99.064110 / 544.357422 fps
Score = 99.111443
dm-phobos2
32.911648 / 127.161560 / 570.975708 fps
Score = 127.194473
dm-phobos2
48.400387 / 160.498642 / 544.204468 fps
Score = 160.576950
dm-inferno
9.882934 / 68.284927 / 632.337830 fps
Score = 68.360641
dm-inferno
14.198334 / 93.907028 / 332.251801 fps
Score = 94.000175
dm-inferno
26.212124 / 143.843079 / 374.973969 fps
Score = 143.946274
ctf-face3
59.399563 / 124.243561 / 415.328003 fps
Score = 124.300003
ctf-face3
74.910858 / 147.954010 / 496.299255 fps
Score = 148.024994
ctf-face3
74.097809 / 172.791504 / 541.098938 fps
Score = 172.898407
ctf-citadel
14.812960 / 98.132889 / 267.922882 fps
Score = 98.223076
ctf-citadel
58.688137 / 127.360237 / 329.528046 fps
Score = 127.576630
ctf-citadel
58.508720 / 151.149460 / 406.241394 fps
Score = 151.429504
dm-asbestos
29.462101 / 126.726898 / 383.890778 fps
Score = 126.785019
dm-asbestos
91.731293 / 172.251251 / 428.752075 fps
Score = 172.388275
dm-asbestos
91.957657 / 215.801804 / 532.628784 fps
Score = 216.027328
SFang
655
Noid,
something is wrong with your first three benchmarks.
There is no way you get same FPS or higher FSP @1600x1200 than @1024X768
Your other benchmarks seems inline with mine. :)
Here is mine.
dm-antalus
23.855852 / 84.394943 / 264.986298 fps
Score = 84.413361
dm-antalus
28.741055 / 119.702202 / 378.418213 fps
Score = 119.713753
dm-antalus
25.584206 / 170.918457 / 517.166382 fps
Score = 170.975632
dom-suntemple
17.524225 / 90.158936 / 269.737335 fps
Score = 90.197487
dom-suntemple
26.891584 / 121.073898 / 377.102142 fps
Score = 121.126717
dom-suntemple
25.550165 / 170.856171 / 479.630676 fps
Score = 170.903809
dm-phobos2
22.915665 / 94.978935 / 526.796753 fps
Score = 94.988266
dm-phobos2
29.816633 / 120.976852 / 586.349548 fps
Score = 121.050468
dm-phobos2
34.664352 / 158.203796 / 585.055786 fps
Score = 158.279846
dm-inferno
10.829886 / 67.017960 / 357.637207 fps
Score = 67.192368
dm-inferno
22.630758 / 91.577324 / 556.199585 fps
Score = 91.687225
dm-inferno
18.593769 / 136.743362 / 437.811066 fps
Score = 136.914215
ctf-face3
23.673235 / 121.267746 / 495.921295 fps
Score = 121.443672
ctf-face3
31.975916 / 148.419159 / 574.777527 fps
Score = 148.487000
ctf-face3
32.331894 / 174.466446 / 577.712219 fps
Score = 174.586472
ctf-citadel
22.644743 / 99.268013 / 333.334991 fps
Score = 99.429146
ctf-citadel
29.690784 / 127.892044 / 349.827209 fps
Score = 128.114960
ctf-citadel
22.456663 / 152.863144 / 434.784607 fps
Score = 153.152039
dm-asbestos
61.804192 / 116.151321 / 350.963867 fps
Score = 116.189629
dm-asbestos
38.838062 / 156.408722 / 490.371857 fps
Score = 156.514481
dm-asbestos
96.449120 / 212.556091 / 626.937012 fps
Score = 212.761856
Noid
2,373
183
Sfang::::
yup ,,, your right
Made my edit.
I know how that happened now too. That was my first run with that tool and it started up windowed. I didnt know better. lol.
It was a direct cut and paste from the results file as you can tell.
sorry for the confusion
anyway ... it didnt do it again ... fixed now by itself ... lol
I need to finish playing that game ... some of those maps I havent seen or played ...
Your rig running 11.5 x 192 ? on a 2400? thats a nice chip
I hope to get my PS fixed soon ... maybe I can get 12 to stablize : )
BoomAm :::
those numbers are kinda low on 3dMArk .. I agree...
But the UT numbers look good for 1533 !
BoomAM
4,546
What Catalyst drivers are you using?
What are the latest drivers?, excluding Catalyst 3.0 & DX9. Where can i get them as well.
Ive just downloaded the Catalyst 2.4 and the latest control panel from rage3d.com
They fix my problem in RalliSport Challenge.
But when i have hardware accelleration enabled in PowerDVD, i get a garbled screan. But when its off, the DVD image is fine.
No biggy but, i would prefer it to work. Windows crashes as well after a min in powerdvd(w/ hardware acceleration), when reboots, and says the the cause of the crash is the 9700/9500 series drivers.
WaTaGuMp
21,207
2,506
The drivers are the 2.4 2.5 and 3.0 is the lateset also Omega has a version of the 2.5 drivers.
Here are all version of ATI drivers
Here
Go here for Omega driversOmega
Slappy00
1,820
4
I consider "good" framerates when things dont skip on my computer,but then again i'm from the doom / Doom2 generation when i guaged how "good" my computer is by how fast the .wad file got loaded ;)
BoomAM
4,546
Hi,
Ive retested 3D Mark, and a now get a whopping score of 10287.
What a difference a new installation of windows makes.
Ive checked the online result browser, and its about 10% behind a DDR memory baced system, which seems about right, cos DDR is suppost to be 10% faster than SDR.
What are the Omega drivers? Ive heard of them, but wasnt quite sure what the difference was.
Also, Which Catalyst version is best?
Do i need DX9 for Catalyst 3.0?
Have you lot any idea about why i get corrupted DVD display when hardware accelleration is on?
Do you think that its just a driver problem, and if the latest drivers dont fix it, then a future driver revision will?
Noid
2,373
183
wow ... hope you didnt have to do W2K? from scatch...
but anyway ... that score looks great
Bovinicus
3,145
You will definitely get a lot higher scores if you upgraded your CPU. The 9700 is a very powerful GPU so a powerful CPU is needed. Wait until socket A is streched to it's max and buy the fastest one you can for your motherboard. You will notice a good increase in speed.
BoomAM
4,546
My CPU will run OC`d. I can OC it to XP1900 on my KT7A-RAID Mobo.
The problem is, that then the AGP speed is 70mhz, and ive heard that radeon cards dont like AGP Speeds above normal.
The KT7A-RAID doesnt do AGP/PCI speed locking before you suggest that.
The Chip will do XP2000, but i need 2v throught it to make it run stable. My Mobo only does up to 1.825v.
WaTaGuMp
21,207
2,506
Hi,
Omega drivers are just drivers modified by the people that make them. According to people that use them they work better for overall gaming, but some say benchmarks are a little lower using them. As for Dx9 you can use that with any drivers from ATI or Omega 2.4 to 3.0. If you do dl Dx9 then your gonna have to get the 330 build for 3DMark to run with Dx9. Driver are a trial and error thing you just have to try them to see how they perform for you. I am glad you did redo your OS too me thats the best way to go, you always get the best scores in benching after doing a fresh OS install. You also start with a clean slate no driver residue sitting around hiding in your system.
Noid
2,373
183
mines at 97mhz when at 191.4 FSB
so is SFangs I believe
also ... I just finished my PS voltage mod... Im at 11.5 x 191.4 now (solid)
and my mem is running 1T again.
I reposted the default clock settings in my 1st post above (edited)
The results below are AFTER oc'g the 9700 to 346.23c/344.65m
(gave me around 10 FPS more)
same 2.5 cat and 6218 driver with OGL and DX performance set to PERFORMANCE
3dMark - 16,149
dm-antalus
14.308272 / 96.743431 / 574.006226 fps
Score = 96.743126
dm-antalus
91.587387 / 139.091614 / 293.015381 fps
Score = 139.121002
dm-antalus
95.171448 / 182.647293 / 649.179688 fps
Score = 182.741013
dom-suntemple
27.800943 / 102.771103 / 477.643921 fps
Score = 102.787804
dom-suntemple
38.223942 / 137.180466 / 475.938385 fps
Score = 137.204315
dom-suntemple
80.215714 / 185.981277 / 541.035339 fps
Score = 186.062958
dm-phobos2
25.791565 / 106.865395 / 559.849182 fps
Score = 106.901543
dm-phobos2
35.998146 / 135.505554 / 557.880188 fps
Score = 135.547668
dm-phobos2
53.430515 / 165.569199 / 547.022583 fps
Score = 165.652802
dm-inferno
13.291777 / 74.078979 / 336.493622 fps
Score = 74.161438
dm-inferno
15.392559 / 101.551384 / 328.455841 fps
Score = 101.635139
dm-inferno
17.632692 / 156.283829 / 410.970062 fps
Score = 156.409897
ctf-face3
64.216209 / 131.808594 / 425.174133 fps
Score = 131.873093
ctf-face3
75.457275 / 154.527115 / 520.407593 fps
Score = 154.606964
ctf-face3
74.400307 / 175.533875 / 544.687439 fps
Score = 175.649063
ctf-citadel
23.500504 / 105.557907 / 295.094482 fps
Score = 105.667809
ctf-citadel
58.625008 / 135.375595 / 382.343536 fps
Score = 135.624924
ctf-citadel
59.227379 / 153.091858 / 406.598633 fps
Score = 153.400101
dm-asbestos
31.909428 / 136.914993 / 387.172607 fps
Score = 136.988632
dm-asbestos
99.426903 / 184.012238 / 454.701172 fps
Score = 184.163895
dm-asbestos
90.855759 / 217.379379 / 532.592834 fps
Score = 217.609024
BoomAM
4,546
Hi again.
It seems to run fine at XP1900 speeds. But for a few extra frames & 5*c more heat, its not worth it, so i`ll clock it back to normal for now.
XP1800@Stock = 10287 3D Marks 2001
XP1800@XP1900 = 10628 3D Marks 2001
